[GRASSLIST:10615] Re: OT : grass+postgis general question
Ing.Peter Misovic peter.misovic at gmail.com
Mon Feb 27 16:36:29 EST 2006
HI,
the problem is that I don't know :) But probably you're right.
Peter
On 2/27/06, Tim De Chant <dechant at nature.berkeley.edu> wrote:
> It's my understanding that GRASS can read files from PostGIS via OGR,
> but it imports them into its own database structure.  Since the two
> databases are fairly different, I don't think GRASS can read and
> write directly from PostGIS (although I'd love to see that).  Please
> correct me if I'm wrong.
> Tim
> __________________________________________
> Tim De Chant
>      University of California, Berkeley
>      Environmental Science, Policy, and Management
>      137 Mulford Hall #3114
>      Berkeley, CA 94720-3114
>      (510) 643-3910
> On Feb 26, 2006, at 1:06 PM, Ing.Peter Misovic wrote:
> > Ok thank you for your information.
> > My original idea (or what I like to see working :)) was that Grass
> > could read data directly from Postgres/PostGIS database and react on
> > database change. Or could it be done through OGR ? Or. I'm just
> > aksing.
> > Thank you,
> > Peter
> >>> Dear all,
> >>> is PostGIS as is supported by GRASS ? Is it possible to import table
> >>> with PostGIS column into Grass ? I've had some problem (the_geom is
> >>> not supported etc.). If not, exists some plans to do that ?
> >>> Thank you,
> >>> Peter
> >> Hello,
> >> OGR support postgis, so I think it's possible to import and export
> >> with
> >> v.in.ogr and v.out.ogr.
> >> Laurent
