[GRASSLIST:9717] Re: drop column?
M S mseibel at gmail.com
Wed Jan 4 12:06:46 EST 2006
yes sorry, that was for the DBF driver.  shoot, thats too bad.  i
guess i'd have to (from reading the archives) create a temp table and
copy over only the colums I want and then re-attach it?  that might be
a handy function.
anyhow, learning postgres is on my TODO list, so hopefully this issue
goes away with more knowledge.
thanks!
On 1/4/06, Markus Neteler <neteler at itc.it> wrote:
> M S wrote:
> >is there a drop column command? i didnt see one in the man pages, and
> >when i tried the    "ALTER TABLE table DROP COLUMN column_name" |
> >db.execute   it didnt like that command but i was able to add
> >columns..
> It depends on the DB driver. I assume that you use DBF? Then it doesn't
> work since DBF is very limited. For all other drivers it should (untested).
> Markus
