[GRASSLIST:9731] Re: Problem using v.digit
Radim Blazek radim.blazek at gmail.com
Thu Jan 5 04:29:52 EST 2006
It can happen only in v.digit not in digitizing tool in qgis.
What do you mean by 'using v.digit from qgis'?
Radim
On 1/4/06, Luca Casagrande <luca.casagrande at gmail.com> wrote:
> Hi to all guys!
> I am using v.digit both from grass and from qgis, and I got this problem:
> after adding in the tab, the value of the item I am editing, all the linux box
> starts going slow till i close the v.digit module.
> This situation happen both with dbf and both with postgresql and with current
> cvs and with stable relase.
> This is the top output while the system is encountering  the problem:
> 10087 geko      25   0  6552 4668 2676 R 38.6  0.9   0:21.92 form
>  8386 root      25   0  100m  57m 3204 S 36.6 11.4   4:55.11 X
> 10058 geko      15   0 15016 7784 5040 S 21.3  1.5   0:35.97 v.digit
> If I select "quit and save" all become normal.
> Thx for help
> Luca
> "Esperienza è il nome che ciascuno da ai suoi errori. (O. Wilde) "
> GENTOO-GIS Development Team
> jabber: casagrande at jabber.linux.it
