[GRASSLIST:9744] Re: vector corruption? after qgis session crash
Ian MacMillan Ian.MacMillan at pomona.edu
Fri Jan 6 09:56:30 EST 2006
I have run into something like this too before.  My hack around it was
to use v.extract where=cat>0 to grab everything out of the damaged
vector file.  My resulting vector was error free.
G'luck,
Ian
On Jan 5, 2006, at 9:35 PM, Dylan Beaudette wrote:
> Hi,
> After a QGIS editing session crash, the vector that i was editing now
> has a
> small problem. when working with this vector i get the following
> warning:
> d.vect pedons
> D1/1: Info->size = 6481, Info->mtime = 1136524613
> D1/1: coor size in head = 6452, real coor file size= 6481
> WARNING: coor files of vector 'pedons at waypts' is larger than it should
> be
>          (29 bytes excess).
> this file seems to work, but the warning is annoying. I have tried
> v.build,
> however this does not fix the problem. is there any quick way to fix
> this, or
> am i going to have to export the vector to text, and re-import it ?
> thanks in advance,
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
This message has been scanned by Postini anti-virus software.
