[GRASSLIST:9745] Re: real color landsat images
Wolfgang Zillig wolfgang.zillig at web.de
Fri Jan 6 12:39:37 EST 2006
Sorry for the late answer!
 I tried it again, but it seems that my idea on how the result has to
look was a bit too realistic. My first try was with an area in Asia and
it showed a lot of forrest and the resulting green did not look very
natural. That was the reason for my mail. Now I tried with a region in
Germany and the result looks better.
(chanals 10/20/30:
http://www.student.kuleuven.ac.be/~s0167070/grass/102030.jpg
chanals 20/40/50:
http://www.student.kuleuven.ac.be/~s0167070/grass/204050.jpg
direkt with r.composite:
http://www.student.kuleuven.ac.be/~s0167070/grass/rgb.jpg)
Thanks a lot for the constructive help!
Wolfgang
Markus Neteler schrieb:
>On Sun, Dec 25, 2005 at 10:05:16AM +0100, Wolfgang Zillig wrote:
>>Hello,
>>I know how to combine the band (_10, _20, _30) to real color images with r.rgb. But then the resolution is limited to 30m. Is there a way to get them in higher resolution with the pan band (_80)? When I use i.fusion.brovey I get always false color pictures. Any idea?
>Wolfgang,
>for me it works:
> http://mpa.itc.it/markus/grass61/demos/landsat_rgb_brovey.jpg
> (ok, a bit too greenish maybe)
>Did you probably invert 10 and 30 or used the wrong flag?
>Markus
