[GRASSLIST:9747] Re: vector corruption? after qgis session crash
Dylan Beaudette dylan.beaudette at gmail.com
Fri Jan 6 12:51:44 EST 2006
On Thursday 05 January 2006 09:35 pm, Dylan Beaudette wrote:
> Hi,
> After a QGIS editing session crash, the vector that i was editing now has a
> small problem. when working with this vector i get the following warning:
> d.vect pedons
> D1/1: Info->size = 6481, Info->mtime = 1136524613
> D1/1: coor size in head = 6452, real coor file size= 6481
> WARNING: coor files of vector 'pedons at waypts' is larger than it should be
>          (29 bytes excess).
> this file seems to work, but the warning is annoying. I have tried v.build,
> however this does not fix the problem. is there any quick way to fix this,
> or am i going to have to export the vector to text, and re-import it ?
> thanks in advance,
Thanks for the tips. Opening the vector in v.digit, adding a new point, and
quitting seemed to fix the problem.
Yay!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
