[GRASSLIST:9778] Re: drop column?
Wolfgang Qual Wolfgang.Qual at gmx.net
Tue Jan 10 10:20:51 EST 2006
Hi everybody,
I just read that SQLITE also does not support "ALTER TABLE table DROP
COLUMN". ("SQLite's version of the ALTER TABLE command allows the user to
rename or add a new column to an existing table. It is not possible to
remove a column from a table." [1]
How to deal with this issue?
Best regards,
Wolfgang
[1] http://www.sqlite.org/lang_altertable.html
> --- Ursprüngliche Nachricht ---
> Von: M S <mseibel at gmail.com>
> An: Markus Neteler <neteler at itc.it>
> Kopie: GRASS Users List <grasslist at baylor.edu>
> Betreff: [GRASSLIST:9717] Re: drop column?
> Datum: Wed, 4 Jan 2006 12:06:46 -0500
> yes sorry, that was for the DBF driver.  shoot, thats too bad.  i
> guess i'd have to (from reading the archives) create a temp table and
> copy over only the colums I want and then re-attach it?  that might be
> a handy function.
> anyhow, learning postgres is on my TODO list, so hopefully this issue
> goes away with more knowledge.
> thanks!
> On 1/4/06, Markus Neteler <neteler at itc.it> wrote:
> > M S wrote:
> > >is there a drop column command? i didnt see one in the man pages, and
> > >when i tried the    "ALTER TABLE table DROP COLUMN column_name" |
> > >db.execute   it didnt like that command but i was able to add
> > >columns..
> > It depends on the DB driver. I assume that you use DBF? Then it doesn't
> > work since DBF is very limited. For all other drivers it should
> (untested).
> > Markus
Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko!
Satte Provisionen für GMX Partner: http://www.gmx.net/de/go/partner
