[GRASSLIST:9792] Re: Bash shell scripting question for batch archiving Grass vectors
Patton, Eric epatton at nrcan.gc.ca
Wed Jan 11 10:45:29 EST 2006
>> Do you know why specifically it may not be the best way to export
>> vectors (or rasters) this way? Assuming the target location the tarred
>> vectors are going to has the same projection and datum, can't it be
>> dragged and dropped?
>My concern is that there may be some other, necessary, information outside
the 'vector' directory. In 'dbf', for example.
>An export-procedure should take care of those as well, while just tarring
the content of 'vector' does not.
>-flo.
Then how about (in PERMANENT):
for map in `g.mlist type=vect pattern='vectorname'`; do tar cvf `basename
$map.tar` ./*/$map* ; done
Would that be sufficient?
~ Eric.
