[GRASSLIST:9794] Re:
Ksenia Konwicki kes at timberline.ca
Wed Jan 11 11:47:05 EST 2006
Good morning Brian,
I'm a pretty new user my self but I will try to answer your question. When I
import and export ESRI grids I do it as ascii files - GRASS doesn't seem to
read the GRIDs directly - if it does, somebody please tell me how. So to
import an ESRI GRID, I export the GRID to ascii and use r.in.arc to import it.
Similar with r.out.arc, I export it from GRASS with an ascii file extension
and then import the ascii into ArcGIS. Using this method, the rasters are
properly configured - ie. no offset because of the difference in the way
raster and pixel coordinates are stored.
If anyone has a better way, I'd be curious to hear it.
Thanks,
Kessie.
Ksenia E. Konwicki, RPF
Ecologist
Timberline Forest Inventory Consultants
1579 9th Avenue
Prince George, BC   V2L 3R8
P (250)562-2628
F (250)562-6942
E kes at timberline.ca
David Finlayson wrote:
> Hey Brian, wise choice.
> When using gdal to import arc grids you need to import the w001001.adf
> (the BIG file) file. (Inside the grid folder). Maybe that will fix it.
> David
> On 1/6/06, Brian Sherrod <bsherrod at ess.washington.edu> wrote:
> > I am new to Grass after spending the last 12 years working on an
> > infernal Windows machine running Arc and ArcGIS.  I am now running SuSE
> > Linux 10.0 on a Dell with an Intel P4, and have Grass 5.0 installed.  I
> > installed gdal 1.3.1 from the SuSE 9.3 RPMs posted on the Hannover Grass
> > website. My problem is when I try to import lidar data formatted as Arc
> > grids.  Grass sends me the following error:
> > ERROR 4:  '/catfish_sm' does not exist in the file system and is not
> > recognised as a supported datset name.
> > I get the same error when trying to import ascii DEMs (USGS DEMs).
> > Anyone have any hints to send me down the correct path?  Wrong
> > installation of gdal?? Path not set correctly?? Many thanks ahead of
> > time for your help.  Cheers.....Brian Sherrod
> David Finlayson
> Marine Geology & Geophysics
> School of Oceanography
> Box 357940
> University of Washington
> Seattle, WA  98195-7940
> USA
> Office: Marine Sciences Building, Room 112
> Phone: (206) 616-9407
> Web: http://students.washington.edu/dfinlays
