[GRASSLIST:9812] v.extract area with holes but without islands
Roger Bivand Roger.Bivand at nhh.no
Fri Jan 13 06:06:34 EST 2006
I have a question about how to extract only a polygon and its holes from a
vector.
The background is that I have a shapefile from a colleague vectorised in
Arc from a raster showing a polygon with holes. The shapefile holes are
also clockwise (curiously), but I think that this is because the vector
shapes were not cleaned before outputting.
When read into GRASS 6 with v.in.ogr, the holes are recognised, but island
polygons are also created, type=area was used.
The same happens when I read the raster into GRASS and vectorise with
r.to.vect - creating the new vector makes one geometry of the external
boundary with holes, and then adds each hole again as an island as a
separate geometry, again type=area.
Finally, it happens again when I use v.extract on the geometry with holes:
the islands get built and added in, type=area.
Is there any way to remove the islands from the vector representation? The
output is to be used for spatial sampling, so sample points falling in the
holes should be discarded. I think v.build is assuming that holes should
be filled with islands in each case.
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
