[GRASSLIST:9886] Re: ps.map multiple rasters??
Tue Jan 17 21:07:23 EST 2006
> > I wonder if there is a way of inserting more than one raster into a
> > map made with ps.map. This is possible with vectors, is it possible
> > with rasters?? how??
> g.manual ps.map:
> For each ps.map run, only one raster map layer (or set of layers or
> imagery group; see below) can be requested. ...
> r.patch could help
also you could make a ps.map Encapsulated PostScript output map, then
place the EPS file(s) within another ps.map container map. Possibly
even a (mostly) blank one if say you want 4 maps arranged as so:
|   Map captions..  |
In the past I have use this to put a sub-set map in a corner showing
map of the country with a region box around the area of detail in the
main map. Worked ok but the resulting Postscript file was huge.
Hamish
