[GRASSLIST:9891] Re: Procedure that I followed for installing GRASS mapserver
Matthew Perry perrygeo at gmail.com
Wed Jan 18 03:26:09 EST 2006
Siddhesh,
  I would suggest using more recent versions of the software. There
have been many changes in gdal and grass in recent years and you'll be
more likely to find support if you use updated software.
 I have had good luck with installing things in this order:
gdal 1.3.1 *without* grass support (http://www.gdal.org/dl/gdal-1.3.1.tar.gz)
grass6
gdal-grass plugin (http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz)
mapserver 4.6.2 (http://cvs.gis.umn.edu/dist/mapserver-4.6.2.tar.gz)
matt
On 1/17/06, siddhesh bhatkar <sid_grass at yahoo.com> wrote:
> 1. Installed proj-4.4.9
> 2. Installed gdal-1.1.9
>     ./configure
>     make
>     make install
> 3. Installed GRASS5.3
> 4. Installed libgrass5_0-1.0.0-1mdk.i586.rpm
> 5. Installed libgdal0-1.1.9-2mdk.i586.rpm
> 6. Installed proj-4.4.9
> 7. Installed freetype-2.1.4
> 8. Installed gd-2.0.12
> 9. Installed libpng-1.2.8
> 10. Installed gdal-1.1.9 with grass support
>     (I think am going wrong here)
>    ./configure --without-python
> --with-grass53=~$USER/libgrass/gis
> --with-libz=/usr/local/lib  --with-png=/usr/local/lib
>                --with-jpeg=/usr/lib
> --with-libtiff=internal   --with-geotiff=internal
>    make
>    make install
>    ldconfig
> 11. cp -f /usr/include/gd.h  /usr/lib/
> 12. Installed mapserver-4.4.1
>    ./configure  --with-proj  --with-ogr
> --with-gdal=/usr/local/bin/gdal-config
> --with-gd=/usr/lib  --with-png
>    make
>    make install
>    ldconfig
> troubleshooting
> mapserv -v
> MapServer version 4.4.1 OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> gdal-config  --formats
> gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 bsb
> xpm sdts raw dted mem jdem envisat elas fit vrt
> usgsdem l1b nitf bmp jpeg2000 gif jpeg png
> gdal_translate --formats
> The following format drivers are configured and
> support output:
>   VRT: Virtual Raster
>   GTiff: GeoTIFF
>   NITF: National Imagery Transmission Format
>   HFA: Erdas Imagine Images (.img)
>   ELAS: ELAS
>   AAIGrid: Arc/Info ASCII Grid
>   DTED: DTED Elevation Raster
>   PNG: Portable Network Graphics
>   JPEG: JPEG JFIF
>   MEM: In Memory Raster
>   GIF: Graphics Interchange Format (.gif)
>   BSB: Maptech BSB Nautical Charts
>   XPM: X11 PixMap Format
>   BMP: MS Windows Device Independent Bitmap
>   PNM: Portable Pixmap Format (netpbm)
>   ENVI: ENVI .hdr Labelled
>   PAux: PCI .aux Labelled
>   MFF: Atlantis MFF Raster
>   MFF2: Atlantis MFF2 (HKV) Raster
>   FIT: FIT Image
> Kindly help
> Thanking u all
> Siddhesh,
> __________________________________________________
> Do You Yahoo!?
> Tired of spam?  Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
Matt Perry
http://www.perrygeo.net
