[GRASSLIST:9892] Re: Procedure that I followed for installing GRASS mapserver
Stephan Holl holl at gdf-hannover.de
Wed Jan 18 03:33:57 EST 2006
Hello siddhesh,
From your listing below I can see that you are using quite old
libraries. I recommend to use a recend gdal-version, because the
grass-driver has improved a lot since then.
Apparently you have installed gdal twice, once from source (step 2) and
once from RPM (step 5) which results in a double-installation. Most
probably this does not work without problems.
So try to use recent libraries and follow the (quite short)
installation in the wiki[1]
This deals with QGIS, but is mainly the same for mapserver since
mapserver users GDAL/OGR to read GRASS-data.
Hope that helps
	Stephan
[1]
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassQgisGdalOgrPlugin
On Tue, 17 Jan 2006 23:13:17 -0800 (PST) siddhesh bhatkar
<sid_grass at yahoo.com> wrote:
> 1. Installed proj-4.4.9
> 2. Installed gdal-1.1.9
>     ./configure
>     make
>     make install
> 3. Installed GRASS5.3
> 4. Installed libgrass5_0-1.0.0-1mdk.i586.rpm
> 5. Installed libgdal0-1.1.9-2mdk.i586.rpm
> 6. Installed proj-4.4.9
> 7. Installed freetype-2.1.4
> 8. Installed gd-2.0.12
> 9. Installed libpng-1.2.8
> 10. Installed gdal-1.1.9 with grass support
>     (I think am going wrong here)
>    ./configure --without-python
> --with-grass53=~$USER/libgrass/gis
> --with-libz=/usr/local/lib  --with-png=/usr/local/lib
>                --with-jpeg=/usr/lib
> --with-libtiff=internal   --with-geotiff=internal
>    make
>    make install
>    ldconfig
> 11. cp -f /usr/include/gd.h  /usr/lib/
> 12. Installed mapserver-4.4.1
>    ./configure  --with-proj  --with-ogr
> --with-gdal=/usr/local/bin/gdal-config
> --with-gd=/usr/lib  --with-png
>    make
>    make install
>    ldconfig
> troubleshooting
> mapserv -v
> MapServer version 4.4.1 OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> gdal-config  --formats
> gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 bsb
> xpm sdts raw dted mem jdem envisat elas fit vrt
> usgsdem l1b nitf bmp jpeg2000 gif jpeg png
> gdal_translate --formats
> The following format drivers are configured and
> support output:
>   VRT: Virtual Raster
>   GTiff: GeoTIFF
>   NITF: National Imagery Transmission Format
>   HFA: Erdas Imagine Images (.img)
>   ELAS: ELAS
>   AAIGrid: Arc/Info ASCII Grid
>   DTED: DTED Elevation Raster
>   PNG: Portable Network Graphics
>   JPEG: JPEG JFIF
>   MEM: In Memory Raster
>   GIF: Graphics Interchange Format (.gif)
>   BSB: Maptech BSB Nautical Charts
>   XPM: X11 PixMap Format
>   BMP: MS Windows Device Independent Bitmap
>   PNM: Portable Pixmap Format (netpbm)
>   ENVI: ENVI .hdr Labelled
>   PAux: PCI .aux Labelled
>   MFF: Atlantis MFF Raster
>   MFF2: Atlantis MFF2 (HKV) Raster
>   FIT: FIT Image
> Kindly help
> Thanking u all
> Siddhesh,
> __________________________________________________
> Do You Yahoo!?
> Tired of spam?  Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060118/a335a6fb/signature.bin
