[GRASSLIST:9899] Re: Procedure that I followed for installing GRASS mapserver
Siddhesh Bhatkar sid_grass at yahoo.com
Wed Jan 18 07:28:35 EST 2006
Hello,
These are the Steps Followed by me.
1. Installed gdal *without* GRASS support
   cd gdal-1.3.1
   ./configure
   make
   su
   make install
2. Installed GRASS 6.0 in my home directory.
   cd grass-6.0.0
   ./configure --prefix=/home/bnagesh
--bindir=/home/bnagesh/bin
--with-postgres-includes=/usr/include/pgsql
--without-odbc --without-fftw
3. While Installing gdal-grass-1.3.1 error
encountered.
   steps as follows
   a.  ln -s /usr/local/lib
/home/bnagesh/grass-6.0.0/lib/*.so
   b. ./configure
--with-gdal=/usr/local/bin/gdal-config
--with-grass=/home/bnagesh/grass-6.0.0
configure: error:
--with-grass=/home/bnagesh/grass-6.0.0/ requested, but
libraries not found!
Why does this error occur? whats the name of the
libraries its looking for? and where are these
libraries located?
Thanking you.
Siddhesh
--- Matthew Perry <perrygeo at gmail.com> wrote:
> Siddhesh,
>   I would suggest using more recent versions of the
> software. There
> have been many changes in gdal and grass in recent
> years and you'll be
> more likely to find support if you use updated
> software.
>  I have had good luck with installing things in this
> order:
> gdal 1.3.1 *without* grass support
> (http://www.gdal.org/dl/gdal-1.3.1.tar.gz)
> grass6
> gdal-grass plugin
> (http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz)
> mapserver 4.6.2
> (http://cvs.gis.umn.edu/dist/mapserver-4.6.2.tar.gz)
> matt
> On 1/17/06, siddhesh bhatkar <sid_grass at yahoo.com>
> wrote:
> > 1. Installed proj-4.4.9
> > 2. Installed gdal-1.1.9
> >     ./configure
> >     make
> >     make install
> > 3. Installed GRASS5.3
> > 4. Installed libgrass5_0-1.0.0-1mdk.i586.rpm
> > 5. Installed libgdal0-1.1.9-2mdk.i586.rpm
> > 6. Installed proj-4.4.9
> > 7. Installed freetype-2.1.4
> > 8. Installed gd-2.0.12
> > 9. Installed libpng-1.2.8
> > 10. Installed gdal-1.1.9 with grass support
> >     (I think am going wrong here)
> >    ./configure --without-python
> > --with-grass53=~$USER/libgrass/gis
> > --with-libz=/usr/local/lib
> --with-png=/usr/local/lib
> >                --with-jpeg=/usr/lib
> > --with-libtiff=internal   --with-geotiff=internal
> >    make
> >    make install
> >    ldconfig
> > 11. cp -f /usr/include/gd.h  /usr/lib/
> > 12. Installed mapserver-4.4.1
> >    ./configure  --with-proj  --with-ogr
> > --with-gd=/usr/lib  --with-png
> >    make
> >    make install
> >    ldconfig
> > troubleshooting
> > mapserv -v
> > MapServer version 4.4.1 OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE
> > SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR
> INPUT=GDAL
> > INPUT=SHAPEFILE
> > gdal-config  --formats
> > gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211
> bsb
> > xpm sdts raw dted mem jdem envisat elas fit vrt
> > usgsdem l1b nitf bmp jpeg2000 gif jpeg png
> > gdal_translate --formats
> > The following format drivers are configured and
> > support output:
> >   VRT: Virtual Raster
> >   GTiff: GeoTIFF
> >   NITF: National Imagery Transmission Format
> >   HFA: Erdas Imagine Images (.img)
> >   ELAS: ELAS
> >   AAIGrid: Arc/Info ASCII Grid
> >   DTED: DTED Elevation Raster
> >   PNG: Portable Network Graphics
> >   JPEG: JPEG JFIF
> >   MEM: In Memory Raster
> >   GIF: Graphics Interchange Format (.gif)
> >   BSB: Maptech BSB Nautical Charts
> >   XPM: X11 PixMap Format
> >   BMP: MS Windows Device Independent Bitmap
> >   PNM: Portable Pixmap Format (netpbm)
> >   ENVI: ENVI .hdr Labelled
> >   PAux: PCI .aux Labelled
> >   MFF: Atlantis MFF Raster
> >   MFF2: Atlantis MFF2 (HKV) Raster
> >   FIT: FIT Image
> > Kindly help
> > Thanking u all
> > Siddhesh,
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam?  Yahoo! Mail has the best spam
> protection around
> > http://mail.yahoo.com
> Matt Perry
> http://www.perrygeo.net
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
