[GRASSLIST:9914] Re: Procedure that I followed for installing GRASS mapserver
Siddhesh Bhatkar sid_grass at yahoo.com
Thu Jan 19 04:19:37 EST 2006
Hello Stephan,
is this the GRASS6 CVS snapshot u used?
http://grass.itc.it/grass60/source/snapshot/grass-6.0.cvs_src_snapshot_2006_01_14.tar.gz
Do i need to download the CVS software too for
updates? or can i do away with it.
Since  u were successful , i would want to follow the
same procedure as urs. Can i proceed with installing
the CVS snapshot of GRASS 6.0?
Kindly Suggest.
Regards
Siddhesh.
--- Stephan Holl <holl at gdf-hannover.de> wrote:
> Hello Siddhesh,
> On Wed, 18 Jan 2006 21:51:01 -0800 (PST) Siddhesh
> Bhatkar
> <sid_grass at yahoo.com> wrote:
> > Hello Stephan,
> > I added the non-standard location of  grass
> library
> > (in my case  ~bnagesh/grass-6.0.0/lib) to the
> > Enviroment variable  LD_LIBRARY_PATH in my .bashrc
> > file.
> > ./configure --with-gdal=/usr/local/bin/gdal-config
> > --with-grass=/home/bnagesh/grass-6.0.0/
> > now creates the Makefile Successfully.
> > But when i run the "make" command i get the
> following
> > error:
> > g++ -Wall -fPIC  -DUSE_CPL
> > -DGRASS_GISBASE=\"/home/bnagesh/grass-6.0.0/\"
> > -I/usr/local/include
> > -I/home/bnagesh/grass-6.0.0//include   -c -o
> > ogrgrassdatasource.o ogrgrassdatasource.cpp
> > ogrgrassdatasource.cpp: In member function `int
> > OGRGRASSDataSource::Open(const char*, int, int,
> int)':
> > ogrgrassdatasource.cpp:212: error: cannot allocate
> an
> > object of type `OGRGRASSLayer'
> > ogrgrassdatasource.cpp:212: error:   because the
> > following virtual functions are abstract:
> > /usr/local/include/ogrsf_frmts.h:176: error:
> > virtual OGRGeometry* OGRLayer::GetSpatialFilter()
> > make: *** [ogrgrassdatasource.o] Error 1
> I did not come accross this error-message.
> It *could* be related to the fact that a GRASS6
> CVS-snapshpt is needed
> for making the GRASS-plugin of GDAL work, but I do
> not know for sure.
> Can anybody confirm?
> We always work with GRASS CVS-versions in
> production, so I have not
> seen this errors.
> Another starting-point could be the
> GRASS-development-mailinglist,
> which dan be found here[1].
> Best regards
> 	Stephan
> [1] http://grass.itc.it/mailman/listinfo/grass5
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
