[GRASSLIST:9915] Re: Procedure that I followed for installing GRASS mapserver
Stephan Holl holl at gdf-hannover.de
Thu Jan 19 04:38:41 EST 2006
Hello Siddhesh,
On Thu, 19 Jan 2006 01:19:37 -0800 (PST) Siddhesh Bhatkar
<sid_grass at yahoo.com> wrote:
> Hello Stephan,
> is this the GRASS6 CVS snapshot u used?
> http://grass.itc.it/grass60/source/snapshot/grass-6.0.cvs_src_snapshot_2006_01_14.tar.gz
> Do i need to download the CVS software too for
> updates? or can i do away with it.
> Since  u were successful , i would want to follow the
> same procedure as urs. Can i proceed with installing
> the CVS snapshot of GRASS 6.0?
> Kindly Suggest.
I have used a CVS-snapshot as well, but I used the CVS-software for
checkout. If you do not want to use the CVS-software, go here[1] and
download a GRASS CVS 6.1 snapshot.
Best
	Stephan
[1] http://grass.itc.it/grass61/source/snapshot/
> --- Stephan Holl <holl at gdf-hannover.de> wrote:
> > Hello Siddhesh,
> > On Wed, 18 Jan 2006 21:51:01 -0800 (PST) Siddhesh
> > Bhatkar
> > > Hello Stephan,
> > > I added the non-standard location of  grass
> > library
> > > (in my case  ~bnagesh/grass-6.0.0/lib) to the
> > > Enviroment variable  LD_LIBRARY_PATH in my .bashrc
> > > file.
> > > ./configure --with-gdal=/usr/local/bin/gdal-config
> > > --with-grass=/home/bnagesh/grass-6.0.0/
> > > now creates the Makefile Successfully.
> > > But when i run the "make" command i get the
> > following
> > > error:
> > > g++ -Wall -fPIC  -DUSE_CPL
> > > -DGRASS_GISBASE=\"/home/bnagesh/grass-6.0.0/\"
> > > -I/usr/local/include
> > > -I/home/bnagesh/grass-6.0.0//include   -c -o
> > > ogrgrassdatasource.o ogrgrassdatasource.cpp
> > > ogrgrassdatasource.cpp: In member function `int
> > > OGRGRASSDataSource::Open(const char*, int, int,
> > int)':
> > > ogrgrassdatasource.cpp:212: error: cannot allocate
> > an
> > > object of type `OGRGRASSLayer'
> > > ogrgrassdatasource.cpp:212: error:   because the
> > > following virtual functions are abstract:
> > > /usr/local/include/ogrsf_frmts.h:176: error:
> > > virtual OGRGeometry* OGRLayer::GetSpatialFilter()
> > > make: *** [ogrgrassdatasource.o] Error 1
> > I did not come accross this error-message.
> > It *could* be related to the fact that a GRASS6
> > CVS-snapshpt is needed
> > for making the GRASS-plugin of GDAL work, but I do
> > not know for sure.
> > Can anybody confirm?
> > We always work with GRASS CVS-versions in
> > production, so I have not
> > seen this errors.
> > Another starting-point could be the
> > GRASS-development-mailinglist,
> > which dan be found here[1].
> > Best regards
> > 	Stephan
> > [1] http://grass.itc.it/mailman/listinfo/grass5
> __________________________________________________
> Do You Yahoo!?
> Tired of spam?  Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060119/8cb2f633/signature.bin
