[GRASSLIST:9922] Re: Problems when compiling GRASS in an Opteron
Paul A Pick paul.pick at ec.gc.ca
Thu Jan 19 09:24:20 EST 2006
> > Did you install gdal?
> I installed it by compiling from the source.
> >GRASS 6.0.2RC4 (etopo2):~ > Error in startup script: ps.map: error while
> >loading shared libraries: libgdal.so.1: cannot open shared object file:
> >No such file or directory
 Is the path to your libgdal.so.1 in /etc/ld.so.conf and
have you run ldconfig since updating /etc/ld.so.conf?
 Does an ldd on your grass binaries show the correct
path to libgdal.so.1?
Systems Analyst/Programmer             MSC/ADS/ISU Gagetown
[CSN] 432 2082 [CIV] 506 422 2000 x 2082 [FAX] 506 422 1443
