[GRASSLIST:9923] using v.buffer: how can I add attributes to a buffer theme?
wqual wolfgang.qual at gmx.net
Thu Jan 19 09:56:28 EST 2006
Hello list,
I created a polygontheme using v.buffer. In the next step, I wanted to add
some attributes to the buffer-theme, but I realized that there was *no
attribute table attached* to it (however, when I load this theme into qgis >>
table view, I can see two lines: id and cat with both values being "1").
Sqlite3 is used as the database.
Is there an easy way to create an attribute table for the buffer-theme?
Thanks && kind regards,
Wolfgang
