[GRASSLIST:9941] Re: compiling grass for cygwin
Wolfgang Zillig wolfgang.zillig at web.de
Sat Jan 21 09:20:57 EST 2006
OK,
it seems that this is not really an easy task.
Is there a simple way to get the dxf support running without compiling
everything?
Thanks
Wolfgang
Richard Greenwood schrieb:
> On 1/21/06, Wolfgang Zillig <wolfgang.zillig at web.de> wrote:
>> Hello,
>> is there somewhere a manual how to compile grass for cygwin? I'm new to
>> cygwin but I'm interested in a few possibilities which are not included
>> in the binary release due to license information:
>> - access to the source respiratory?
>> - what compiler do I need?
>> - where to find and install the right libraries for gdal, dxf, mrsid, ...
>> - compiling
>> I'm really sorry if this may sound stupid experienced users but my
>> knowledge in cygwin is very limited
>> Kind regards
>> Wolfgang
> There are some notes here:
>     http://geni.ath.cx/grass.html#toc8
> It can be very challenging. I would suggest that you install from the
> precompiled binaries and test your setup before trying to compile from
> source because then you will have a environ met from which to start.
> If you are familiar with Linux/Unix then the Cygwin build tools will
> be familiar.
> HTH
> Richard Greenwood
> richard.greenwood at gmail.com
> www.greenwoodmap.com
