[GRASSLIST:9951] R, kriging and grass6
ivan marchesini marchesini at unipg.it
Mon Jan 23 05:47:10 EST 2006
Hi to all...
we are triyng to use kriging using R and grass6,
We have seen a lot of documentation about R and GRASS5 but not so many
about grass6...
the problem is that we are trying to do an interpolation using the
functions gmeta6 and kriging...
if we are not wrong, the R library GRASS is developed for grass5 and
inside there is the function krige.G that use the location data acquired
using the gmeta() function...
the problem is that we have found the gmeta6() function but not the
krige.G6 function and obvously the krige.G doesn't work using the
location data of grass6 (obtained using gmeta6)
how can we simply solve this problem....
thank you
Ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
