[GRASSLIST:9983] Re: configure: error: *** Unable to locate GDAL library.
Rochelle MIranda r0chelle_miranda at yahoo.com
Tue Jan 24 23:48:08 EST 2006
Hello Hamish
As u said i added /usr/local/lib to the
/etc/ld.so.conf as root and ran ldonfig.Do i need to
relogin into my system for the changes to come to
effect?
I tried installing grass-6.0.0 but it gives me the
same errors as before.
Also as u suggested i tried installing latest version
of gdal.
when i run the "make" command for installing
gdal-1.3.1
i get following errors errors
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/home/r0chelle/gdal-1.3.1'
make: *** [check-lib] Error 2
r these packages not debugged already?
Please help me
Rochelle
--- Hamish <hamish_nospam at yahoo.com> wrote:
> > Even though i have installed gdal-1.1.9 on my
> linux
> > system.
> that is a very old version now, consider upgrading.
> > On running the ./configure command for installing
> > grass-6.0.0 i get the following error
> > checking for GDALOpen... no
> library.
> > These r the files tht are present in the below
> > mentioned directories
> > /usr/lib/libgdal.1.1.so
> > /usr/local/lib/libgdal.so.1.4.1
> > /usr/local/lib/libgdal.la
> > /usr/local/lib/libgdal.a
> > /usr/local/lib/libgdal.1.1.so
> make sure that /usr/local/lib is listed in your
> /etc/ld.so.conf file and
> (as root) run /sbin/ldconfig.
> I have added this suggestion to the Wiki FAQ page:
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassFAQPage
> Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
