[GRASSLIST:9992] Re: Problem using v.to.db - option cat
Wolfgang Qual Wolfgang.Qual at gmx.net
Wed Jan 25 04:16:22 EST 2006
Hi Rene,
thanks for this hint. Works fine (one needs to specify the output file)!
so I did:
v.category in=stream out=stream_tmpd option=del
v.category in=stream_tmpd out=stream_newcat option=add
#delete temp data.
Cheers,
Wolfgang
--8<--------------------
> Greets, Rene
> >Hi list,
> >I tried to assign unique cat-values to a vector (copy of
> streams at PERMANENT,
> >spearfish dataset)file using v.to.db. I expected each row to get a unique
> >cat-value (1,2,3 ...), but received a different result: in total I have
> >three different values for cat (1,2 and 3 like
> 1,1,1,2,2,2,2,2,3,3,2,2,2,1).
> >How can I assign unique cat-values?
> >Greetings,
> >Wolfgang
10 GB Mailbox, 100 FreeSMS/Monat http://www.gmx.net/de/go/topmail
+++ GMX - die erste Adresse für Mail, Message, More +++
