[GRASSLIST:10007] Re: Filling with flood
Ian MacMillan Ian.MacMillan at pomona.edu
Wed Jan 25 12:11:12 EST 2006
Hi all, an alternate way that I have made reservoirs is to use
r.contour and make only the one contour line that I care about.  Then
use v.digit to modify that line at the point that I want the dam.
Convert that vector line to an area, and then back to a raster and
voila, you have a surface that is at the height of your reservoir.
This was a relatively fast method for me.
-Ian
On Jan 25, 2006, at 7:34 AM, Māris Nartišs wrote:
> Hi,
> How I did it:
> Creating dam:
> 1) With r.digit digitise map dam line; Assign correct height to it;
> 2) Grow it to 2 cells atleast to avoid any holes in dam;
> 3) With r.mapcalc add dam to DEM.
> Filling lake:
> 1) With r.digit create map with atleast one cell with any value below
> target water level (seed);
> 2) Feed in DEM, seed, target water level to r.lake.
> You'r done!
> Maris.
> Attached:
> sm_ice.jpg - screenshot form movie showing Smiltene palaeolake and
> possible ice margin, north Vidzeme, Latvia. Created with described
> steps, only instead of r.lake I used r.mapcalc with script (~20h to
> get such map on P4 3GHz compared to 1min on 800MGz PIII with r.lake).
> r_lake.zip - source code of new GRASS module. Use at Your own risk!
> Currently it lacks  nice blue color gradient for output maps. Any
> comments - welcome.
> 2006/1/25, RAVI KUMAR <ravivundavalli at yahoo.com>:
>> Hi
>> It will be nice if I can get a workedout example
>> where in a DEM is used to create a Dam and then flood it.
>> Ravi
>> Hamish <hamish_nospam at yahoo.com> wrote:
>>> I have a surface of watershed and wish to simulate a dam
>>> to see the area of inundation (flooding).
>>> Please suggest a simple method in GRASS6 to create a reservoir (Dam)
>> d.rast.edit or r.digit+r.patch to make the dam, then use
>> r.basins.fill?,
>> r.fill.dir? or the module recently (in the last month) announced on
>> the
>> mailing list to fill depressions & r.mapcalc to compare/crop.
>> Hamish
>>  ________________________________
>> Bring words and photos together (easily) with
>>  PhotoMail - it's free and works with your Yahoo! Mail.
> <sm_ice.jpg>
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by Postini anti-virus software.
