[GRASSLIST:10013] Re: How can I create an index on the cat-column?
Radim Blazek radim.blazek at gmail.com
Thu Jan 26 06:12:44 EST 2006
On 1/26/06, Wolfgang Qual <Wolfgang.Qual at gmx.net> wrote:
> Hi grass-users,
> Recently, I read the following (g.manual v.to.db):
> "If the module is apparently slow and the map attributes are stored in an
> external DBMS such as PostgreSQL, it is highly recommended to create an
> index on the key (category) column."
> How is this done?
Index is created automaticaly by most of GRASS modules.
You only need to create index manualy for tables connected by
v.db.connect.
Radim
> Best regards,
> Wolfgang
> Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko!
> Satte Provisionen für GMX Partner: http://www.gmx.net/de/go/partner
