[GRASSLIST:10017] Re: How can I create an index on the cat-co lumn?
Radim Blazek radim.blazek at gmail.com
Thu Jan 26 08:53:40 EST 2006
On 1/26/06, Patton, Eric <epatton at nrcan.gc.ca> wrote:
>  On 1/26/06, Wolfgang Qual <Wolfgang.Qual at gmx.net> wrote:
> >> Hi grass-users,
> >> Recently, I read the following (g.manual v.to.db):
> >> "If the module is apparently slow and the map attributes are stored in
> an
> >> external DBMS such as PostgreSQL, it is highly recommended to create
> an
> >> index on the key (category) column."
> >> How is this done?
> >Index is created automaticaly by most of GRASS modules.
> >You only need to create index manualy for tables connected by
> >v.db.connect.
> >Radim
> Is it possible to build an index on cat values if you are only using the dbf
> driver?
No.
Radim
> I have a large dbf connected to a vector through v.db.connect and I've
> noticed during v.digit
> sessions that updating/querying attributes through the 'form' interface
> takes a few seconds
> to refesh per record.
> ~ Eric.
