[GRASSLIST:10020] Re: " make" errors while compiling gdal-1.3.1
Rochelle MIranda r0chelle_miranda at yahoo.com
Fri Jan 27 01:01:02 EST 2006
Hello Maris
Thanks a Lot for writing back to my query. As u
suggested there was a conflict betn the hdf4 and the
seperate netcdf installed on my system.
I went through the URL u gave.
On configuring gdal-1.3.1 without the hdf4 support
everything seems to be working fine
Regards
R0chelle
--- Mâris Nartiðs <maris.nartiss at gmail.com> wrote:
> Some time a go when I was workin on GRASS/GDAL
> ebuilds for Gentoo, I
> recall similar problem. There is conflict between
> NetCDF and HDF4.
> IIRC best soltion was to use only one of them.
> Compilation worked fine, if HDF4 was compiled with
> szip flag, but
> there was note, that GDAL may fail on HDF4 data
> loading. I had no
> HDF4/NetCDF data to test it, so I cant say anything
> about faling
> during runtime.
> See more:
> http://bugs.gentoo.org/show_bug.cgi?id=89030
> Maris.
> Details from Gentoo bugzilla:
> __________________________
> HDF4 and NetCDF _CANNOT_ be compiled into the same
> package.  HDF4 contains some
> of the code from NetCDF 2.x, and thus there are
> symbol conflicts.  I mentioned
> this in bug #39942, but I guess it was missed.  This
> same problem also currently
> affects the GDAL 1.2.5 ebuild.
> I just wish I understood why.  Can you
> explain why compiling HDF4 with szip support fixes
> the conflicts?
> I just found Bug#96187 and it says - "Also this is
> not easy to catch
> because it compiles fine and only causes problems at
> runtime when the wrong
> function gets linked / called."
> 2006/1/25, Rochelle MIranda
> <r0chelle_miranda at yahoo.com>:
> > Hello Hamish
> > These are some of the few lines preceeding the
> error
> > messages. hope this will help u diagnos the
> > problem.Please look in.
> > /usr/lib/libnetcdf.a(attr.o)(.text+0x3f0): In
> function
> > `NC_findattr':
> > : multiple definition of `NC_findattr'
> > /usr/lib/libmfhdf.a(attr.o)(.text+0x1e0): first
> > defined here
> > /usr/bin/ld: Warning: size of symbol `NC_findattr'
> > changed from 124 in /usr/lib/libmfhdf.a(attr.o) to
> 140
> > /usr/lib/libnetcdf.a(nc.o)(.text+0x60): In
> function
> > `NC_check_id':
> > : multiple definition of `NC_check_id'
> > /usr/lib/libmfhdf.a(file.o)(.text+0x0): first
> defined
> > here
> > /usr/bin/ld: Warning: size of symbol `NC_check_id'
> > changed from 67 in /usr/lib/libmfhdf.a(file.o) to
> 61
> > /usr/lib/libnetcdf.a(var.o)(.text+0x5b0): In
> function
> > `NC_var_shape':
> > : multiple definition of `NC_var_shape'
> > /usr/lib/libmfhdf.a(var.o)(.text+0x1d0): first
> defined
> > here
> `NC_var_shape'
> > changed from 520 in /usr/lib/libmfhdf.a(var.o) to
> 373
> > collect2: ld returned 1 exit status
> > make[1]: *** [libgdal.la] Error 1
> > make[1]: Leaving directory
> `/home/bnagesh/gdal-1.3.1'
> > make: *** [check-lib] Error 2
> > R0chelle
> > --- Hamish <hamish_nospam at yahoo.com> wrote:
> > > > As u said i added /usr/local/lib to the
> > > > /etc/ld.so.conf as root and ran ldonfig.Do i
> need
> > > to
> > > > relogin into my system for the changes to come
> to
> > > > effect?
> > > No, as soon as ldonfig is done it should be ok.
> > > try:
> > > $ locate gdal-config
> > > $ locate libgdal
> > > where are they?
> > > > I tried installing grass-6.0.0 but it gives me
> the
> > > > same errors as before.
> > > >> On running the ./configure command for
> installing
> > > >> grass-6.0.0 i get the following error
> > > >> checking for GDALOpen... no
> > > >> configure: error: *** Unable to locate GDAL
> > > library.
> > > look at the end of config.log for the error.
> > > > Also as u suggested i tried installing latest
> > > version
> > > > of gdal.
> > > > when i run the "make" command for installing
> > > > gdal-1.3.1
> > > > i get following errors errors
> > > `/home/r0chelle/gdal-1.3.1'
> > > > r these packages not debugged already?
> > > We need to see a dozen or so lines prior to that
> as
> > > well. That just
> > > tells us where it stopped, not why.
> > > Hamish
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam?  Yahoo! Mail has the best spam
> protection around
> > http://mail.yahoo.com
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
