[GRASSLIST:10027] projection problems
Kirk R. Wythers kwythers at umn.edu
Fri Jan 27 12:52:04 EST 2006
It seems that I could use some very basic explanation concerning
locations and projections. I am trying to read several shape files
into a single location. However, I am getting a projection error on
some of them.
g.region -p for the location is:
GRASS 6.1.cvs (minnesota_utm):~ > g.region -p
projection: 1 (UTM)
zone:       15
datum:      nad83
ellipsoid:  grs80
north:      5472415.17999963
south:      4816310.42
west:       189788.954
east:       761663.27300056
nsres:      0.99999963
ewres:      1.00000056
rows:       656105
cols:       571874
and v.info for the state outline shape file (which read in fine with
v.in.ogr) is:
GRASS 6.1.cvs (minnesota_utm):~ > v.info mn_state
| Layer:    mn_state
Organization:                     |
| Mapset:   pls                            Source
Date:                      |
creator:                  |
| Database: /Volumes/disk1/home1/kwythers/
grassdata                          |
Title:
| Map Scale:
1:1                                                            |
| Map format:
native                                                         |
|   Type of Map:  Vector (level:
2)                                          |
|   Number of points:       0               Number of areas:
1          |
|   Number of lines:        0               Number of islands:
1          |
|   Number of boundaries:   1               Number of faces:
0          |
|   Number of centroids:    1               Number of kernels:
0          |
|   Map is 3D:
0                                                |
|   Number of dblinks:
1                                                |
|   Projection: UTM (zone
0)                                                 |
|            N: 5472414.182    S:
4816310.425                                |
|            E: 761662.273    W:
189788.954                                  |
|            B: 0.000         T:
0.000                                       |
|   Digitize threshold:
0.00000                                              |
Comments:
Although I do notice that the projection reads UTM (zone 0) which
seems odd to me... it should be zone 15.
Now for the really fun part...
If I try and read another shape file into the location, I get the
projection error about not matching the current location:
GRASS 6.1.cvs (minnesota_utm):~ > v.in.ogr dsn=~/projects/mn_dnr/
shape_files/pls_corners_btrees/county/cook/ output=cook_test
ERROR: Projection of dataset does not appear to match current location.
        LOCATION PROJ_INFO is:
        datum: nad83
        towgs84: 0.000,0.000,0.000
        proj: utm
        ellps: grs80
        a: 6378137.0000000000
        es: 0.0066943800
        f: 298.2572221010
        zone: 15
        cellhd.proj = 0 (unreferenced/unknown)
        You can use the -o flag to v.in.ogr to override this check.
        Consider to generate a new location with 'location' parameter
from
        input data set.
If I use the -o flag (or location=some_new_location) the file comes
in as projection (0) x,y
I asked one of our ARC/GIS folks downstairs to see if he could import
the shape files and lay them on top of each other and he did not have
any trouble. I am wondering if I have set something very basic up wrong.
Any suggestions for diagnosing this problem and getting these shape
files to match up would be much appreciated.
Thanks
