[GRASSLIST:10056] Re: which is the best method to calculate the distance between two points?
Patricio Toledo patricioantoniotoledo at gmail.com
Mon Jan 30 15:36:53 EST 2006
> Try d.geodesic.d.geodesic - Displays a geodesic line, tracing the
> shortest distance between two geographic points along a great circle,
> in a longitude/latitude data set. (from the grass 6 manual)--Odoardo Zecca
d.geodesic does not work on UTM locations and the result is on screen, i need it
on a variable to make some calculations.
still trying
Thanks,
