[GRASS-user] xganim Error: attempt to add non-widget child "DropSiteManager" to parent "xganim" which supports only widgets
Nagesh Bhatkar bnagesh at nio.org
Thu Jul 6 00:28:21 EDT 2006
Allright Sir. Since its quite hard to track down this bug, should
i revert back to LessTif if theres a possible way to remove the error
LessTif was giving:
Warning: XmManager ClassInitialize: XmeTraitSet failed
or is there no way i can use the xganim module of GRASS on my system.
Thanks and Regards
Nagesh
Glynn Clements wrote:
>Nagesh Bhatkar wrote:
>>As u suggested i installed the Open motif package on my system.
>>Compiled the code xganim successfully.
>>However i get the following error at run time:
>>X Error of failed request: BadWindow (invalid Window parameter)
>>Major opcode of failed request: 19 (X_DeleteProperty)
>>Resource id in failed request: 0x0
>>Serial number of failed request: 93
>>Current serial number in output stream: 97
>This usually indicates a bug in one of the components of the desktop
>environment (window manager, clipboard manager etc), where the program
>stores an invalid window ID in property describing a selection or
>other shared resource.
>Unfortunately, such issues are quite hard to track down; even if you
>can identify the malformed property, there isn't any systematic way to
>identify which program created the property.
