[GRASS-user] gdal, grass, and qgis
Maciek Sieczka werchowyna at epf.pl
Fri Jul 7 14:01:10 EDT 2006
On Fri, 07 Jul 2006 18:26:59 +0200
Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> I tied compiling gdal with grass support for use with qgis, following
> http://grass.gdf-hannover.de/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin
> and http://casoilresource.lawr.ucdavis.edu/drupal/node/123. Vectors go
> well, but I cannot load grass rasters in qgis:
> ERROR 4: `/home/Documenti/datigrass/Toscana/PERMANENT/cellhd/d260160'
> not recognised as a supported file format.
What versions? Using current Grass and Qgis CVS, Gdal 2006-02-10 and
gdal-grass 1.3.1.1 it works for me.
> However, gdalinfo can see the layer:
> $ gdalinfo /home/Documenti/datigrass/Toscana/PERMANENT/cellhd/d260160
> Driver: GRASS/GRASS Database Rasters (5.7+)
> Size is 11530, 8919
> Coordinate System is `'
> Origin = (1599890.279998,4855983.000000)
> Pixel Size = (0.63492801,-0.63437605)
> Any hint on how to solve this?
At first I thought maybe the missing projection was the case but QGIS
reads my xy Grass rasters fine.
How about this:
reads: "New plugin version as of 19 Oct 2005, requires GDAL 1.3.1 or
later"
Are you sure your Gdal instalation is new enough?
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
