[GRASS-user] gdal, grass, and qgis
Markus Neteler neteler at itc.it
Fri Jul 7 18:18:13 EDT 2006
On Fri, Jul 07, 2006 at 06:26:59PM +0200, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> I tied compiling gdal with grass support for use with qgis, following
> http://grass.gdf-hannover.de/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin
> and http://casoilresource.lawr.ucdavis.edu/drupal/node/123. Vectors go
> well, but I cannot load grass rasters in qgis:
> ERROR 4: `/home/Documenti/datigrass/Toscana/PERMANENT/cellhd/d260160'
> not recognised as a supported file format.
> However, gdalinfo can see the layer:
> $ gdalinfo /home/Documenti/datigrass/Toscana/PERMANENT/cellhd/d260160
> Driver: GRASS/GRASS Database Rasters (5.7+)
> Size is 11530, 8919
> Coordinate System is `'
> Origin = (1599890.279998,4855983.000000)
> Pixel Size = (0.63492801,-0.63437605)
> Any hint on how to solve this?
Paolo,
are you sure that QGIS uses the same GDAL installation (and sees
the plugin .so files)?
ldd may help to find out.
Markus
> All the best.
> pc
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.3 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFErotT/NedwLUzIr4RAptxAJ49MsP+jYgLFjYjOYIimjPj7cqVCACfU15x
> e8h7EPW2+GUGadf57Hh9nxc=
> =OUU1
> -----END PGP SIGNATURE-----
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
