[GRASS-user] points in polygon query
Massimiliano Cannata massimiliano.cannata at supsi.ch
Fri Jul 14 04:04:03 EDT 2006
Hi all,
I have a task to accomlpish but I don't know how to perform it...
Maybe someone can give me some hinits.... :-)
I have a points layer and a polygon layer.
I want to generate a map with the geometry of the polygons and an
attribute that is the count of the points that fall inside.
Example:
polygons: Municipalities
points: car accidents
resulting map: Municipalities represented for number of car accidents
Thanks you all,
Maxi
Dr. Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
