[GRASS-user] v.in.ascii error message
gary lists at lazygranch.com
Fri Jul 14 16:07:51 EDT 2006
I changed the input format but got the same cryptic error message.
Markus Neteler wrote:
> On Thu, Jul 13, 2006 at 01:30:43AM -0700, gary wrote:
>>I find this error message from v.in.ascii a bit cryptic.
>>grass command:
>>v.in.ascii input=/usr/localsrc/utm/PERMANENT/site.dat output=sites5
>>format=point fs=| skip=0 x=1 y=2 z=0 cat=0
>>error message:
>>Maximum input row length: 24
>>Maximum number of columns: 2
>>Minimum number of columns: 0
>>GRASS_INFO_ERROR(15897,1): x column number > minimum last column number
>>GRASS_INFO_ERROR(15897,1): (incorrect field separator?)
>>The file site. dat is one line as follows
>>W115 58 2.4|N36 27 20.9
>>The default separator is "pipe", so I'm sure the delimiter is fine. Any
>>idea what I'm doing wrong here?
> I guess that formatting should be
> 115:58:2.4W|36:27:20.9N
> instead of
> Markus
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
