[GRASS-user] [GRASSLIST:1154] Re: rectifying vectors
Fri Jul 14 23:00:45 EDT 2006
Kirk Wythers wrote:
> I have moved a series of dxf files into grass with the new v.in.dxf.
> However, I have discovered that the original dxf files were not
> georectified. They came from some sort of xy location system. I have
> been thinking about ways to rectify the grass vectors I created. The
> only ideas I have come up with would involve writing the new grass
> vectors out with v.out.ascii, developing a "correction factor",
> applying the correction to the ascii files, then reading the ascii
> files back into grass with v.in.ascii.
> Does anyone know of less cumbersome approach?
Hi Kirk,
It is typical for DXF data to be unprojected. Use v.transform.
for something more interactive you might try some mix of {v.to.rast +
i.vpoints + analyze the group/POINTS file} to get the v.transform
parameters, or try Michael's new GeoRectifing tool (gis.m
File->GeoRectify)?
Hamish
