[GRASS-user] point reprojection: v.proj vs cs2cs results
ivan marchesini marchesini at unipg.it
Mon Jul 24 05:24:46 EDT 2006
Dear Users,
I need to reproject a point (280799|4802457) from location A to location
B
these are the PROJ_INFO files:
_______________________
LOCATION A (UTM ED50)
datum: eur50
towgs84: -87.000,-98.000,-121.000
proj: utm
ellps: international
a: 6378388.0000000000
es: 0.0067226700
f: 297.0000000000
zone: 33
and
Location B (Gauss-Boaga EST Rome40)
datum: rome40
towgs84: -104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
proj: tmerc
es: 0.0067226700
f: 297.0000000000
lat_0: 0.0000000000
lon_0: 15.0000000000
k_0: 0.9996000000
x_0: 2520000.0000000000
y_0: 0.0000000000
__________________
if I try to use v.proj for the point, from location A to Location B,
I obtain this coordinate (into location B):
2300732.60711273|4802279.27423501
Instead, if I use cs2cs:
echo "280799 4802457 263" | cs2cs -v +init=epsg:23033 +to +proj=latlong
+datum=WGS84 |cs2cs -v +proj=latlong +datum=WGS84 +to +init=epsg:3004
+towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
(where:
cat /usr/share/proj/epsg | grep Italy -A1 | grep "zone 2" -A1
# Monte Mario / Italy zone 2
<3004> +proj=tmerc +lat_0=0 +lon_0=15 +k=0.999600 +x_0=2520000 +y_0=0
+ellps=intl +units=m +no_defs  <>
and
cat /usr/share/proj/epsg | grep UTM -A1 | grep ED50 -A1 |grep 33 -A1
# ED50 / UTM zone 33N
<23033> +proj=utm +zone=33 +ellps=intl +units=m +no_defs  <>
I obtain this output:
# ---- From Coordinate System ----
#Lat/long (Geodetic)
# +proj=latlong +datum=WGS84 +ellps=WGS84 +towgs84=0,0,0
# ---- To Coordinate System ----
#Transverse Mercator
#       Cyl, Sph&Ell
# +init=epsg:3004 +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
# +proj=tmerc +lat_0=0 +lon_0=15 +k=0.999600 +x_0=2520000 +y_0=0
+ellps=intl
# +units=m +no_defs
#Universal Transverse Mercator (UTM)
#       Cyl, Sph
#       zone= south
# +init=epsg:23033 +proj=utm +zone=33 +ellps=intl +units=m +no_defs
2300810.30      4802292.11 425.44
As you can see the resulted coordinate is quite different from the
previous one...
can someone explain me this strange result???
surely it is my fault, but I can't understand where I'm wrong
Thanks
Ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
jabber: geoivan73 at jabber.org
