[GRASS-user] Re: [Qgis-user] From points to areas?
ivan marchesini marchesini at unipg.it
Tue Jul 25 14:27:56 EDT 2006
Dear all,
attached you can find the script v.cluster for grass gis...
It needs R installed in your computer.
the script perform a spatial clustering of a points maps, partitioning
(clustering) the data into 'k' clusters ``around medoids'', a more
robust version of K-means.
the script is heavily based on tutorial
(http://grass.itc.it/pipermail/grassuser/2006-July/035288.html) by Dylan
Beaudette, UC Davis (many thanks!!!!)
Please try it before using it for production.... it can have some bugs!!
cheers
Ivan
On mar, 2006-07-25 at 14:51 +0200, Martin Wegmann wrote:
> Dear Tom,
> have a look at this thread, perhaps that's what you are looking for:
> a script v.cluster can be found here (related to the previous thread)
> http://grass.itc.it/pipermail/grassuser/2006-July/035307.html
> cheers, Martin
> On Tuesday 25 July 2006 14:36, listen at thomas-zastrow.de wrote:
> > Dear QGIS-users,
> > I'm not sure if I'm right here or if my question is realy silly ... I'm new
> > to QGIS and GIS general, read something about GRASS, googlet around but I
> > can't find a solution ...
> > So, what I have is a map with points, produced by QGIS, works perfect. Now,
> > these points have different colors and I want to cluster them into areas.
> > Is there any software which can do this automatically? Or has anybody an
> > idea what I have to do?
> > For example:
> > http://www.thomas-zastrow.de/temp/maps.png
> > The first map shows what I have now - points with different colors on a
> > map. The second one is - ähem - what it should look like, the points are
> > clustered into areas (I did this manually with the GIMP).
> > Thank you very much, I'm thankful for every hint!
> > Best regards,
> > Tom
> > Qgis-user mailing list
> > Qgis-user at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
jabber: geoivan73 at jabber.org
Type: application/x-shellscript
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060725/e11d3928/v.bin
