[GRASS-user] mapcalc NULL issue
    Wolfgang
    wollez at gmx.net
    Thu Jun  8 08:12:06 EDT 2006
out of the manual from r.mapcalc
Example: The users wants the NULL-valued cells to be treated like zeros.
To add maps A and B (where B contains NULLs) to get a map C the user can
use a construction like:
C=A + if(isnull(B),0,B)
Cheers
Wolfgang
Carlos "Guâno" Grohmann schrieb:
> Hello all.
> I have two rasters (SRTM_V2), one has data on the continental area,
> with zero values in the ocean. The other (SRTM_30 PLUS) has values for
> all region. I'd like to patch them, using r.mapcalc, like this:
> if srtmv2==0 OR srtmv2==NULL, then use value from srtm30plus, else srtmv2.
> I tried this in mapcalc:
> test=if(A==0||isnull(A), B,A)
> but it didn't work. the result was the same as test=if(A==0, B,A).
> So how can I manage to get the condition for zero and null at the same
> time? I mean, I can do this in a single operation, right? Or do I need
> to make two operations?
> cheers
