[GRASS-user] r.los error message
Mon Jun 12 00:48:46 EDT 2006
> gary wrote:
> > When running r.los, I am getting the error message "lat/long
> > databases not yet supported".
> > The X,y coordinates were printed back correctly in the error
> > message. I entered them in the format Ndd hh mm.m Wdd hh mm.m. I
> > made sure the location is in the raster map.
> > I'm running Grass60. BTW, I did look into the suggestion of using
> > r.cva,  but it doesn't seem to be supported in Grass 6.
> Ignore the prior post. I found a tutorial explaining the error message
> and will attempt to convert my data to UTM.
> <http://cemml.carleton.ca:8080/OGUG/Members/smitch/raster-elevation-data-in-grass-workshop>
Nevertheless the error message was misleading so I've changed it in CVS.
