[GRASS-user] Fw: another v.in.ogr question
Kirk R. Wythers kwythers at umn.edu
Mon Jun 12 22:48:45 EDT 2006
On Jun 12, 2006, at 6:30 PM, Brent Wood wrote:
> On Mon, 12 Jun 2006, Stephan Holl wrote:
>> Hello Kirk,
>> On Fri, 9 Jun 2006 13:32:15 -0500 "Kirk R. Wythers"
>> <kwythers at umn.edu>
>> wrote:
>>> Is it possible to read multiple tables from postgis (postgresql)
>>> into grass with v.in.ogr? I seem to be able to only read in the
>>> table
>>> that contains the geometry data. I tried creating a postgresql view
>>> that contains all the columns (from multiple tables) that I need,
>>> however, v.in.ogr does not seem to see the view.
>> Did you make sure that the view is also included in the
>> table geometry_columns?! Try using the addgeometrycolumn() from
>> within
>> postgis.
>> AFAIK this is needed for OGR to work with views as well.
> The AddGeometryColumns() function will create both the column
> itself as
> well as adding the record in the geometry_columns table. I don't
> think it
> can be used to just add the record.
> So in cases such as views, where the geometry column already
> exists, and
> you need to add the metadata record in the geometry_colunms entry, you
> need to do this manually.
Manual addition to the geometry_columns table did the trick. Thanks
both of you.
Kirk
