[GRASS-user] gdalwarp latlong to UTM
Matthew Perry perrygeo at gmail.com
Thu Jun 15 11:48:23 EDT 2006
gary,
 It is possible that the originial image doesn't have any projection
info. Try gdalinfo and see. If not, you can use the -s_srs
'+proj=latlon' parameter to define the source projection.
- matt
On 6/14/06, gary <lists at lazygranch.com> wrote:
> I've tried using gdalwarp to convert from latlong to UTM. I used this
> format, as pulled from the remotesensing.org website:
> gdalwarp -t_srs '+proj=utm +zone=11 +datum=WGS84' raw_spot.tif utm11.tif
> After conversion, r.los believes the new file is still in latlon format.
> [I used the override option.] I tried using the -te option, but can't
> seem to get gdalwarp to accept it.
> Questions:
> 1) Would the -te options help
> 2) If so, can someone post a command line using it with UTM
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Matt Perry
http://www.perrygeo.net
