[GRASS-user] grass instalation on fc4
Fri Jun 16 20:10:29 EDT 2006
Ana Soares wrote:
> Hi :-)
> I get this problem :
> [root at ana gdal-1.3.1]# ./configure --without-grass
> --with-hdf4=/usr/local/hdf4.2r1 --with-libtiff=internal
> --with-geotiff=internal --with-python --without-ogdi --without-libgrass
> --enable-shared
GDAL problems should really go to the GDAL list.
> checking for SDreaddata in -lmfhdf... no
> checking for SDreaddata in -lhdf4... no
> configure: error: HDF4 support requested with arg /usr/local/hdf4.2r1, but
> neither hdf4 nor mfhdf lib found
> But :
> ]# rpm -Uhv hdf-4.2r1-6.fc4.i386.rpm
> Preparing...                ###########################################
> [100%]
>         package hdf-4.2r1-6.fc4 is already installed
You need the corresponding -devel package, which is probably:
http://download.fedora.redhat.com/pub/fedora/linux/extras/4/i386/hdf-devel-4.2r1-6.fc4.i386.rpm
