[GRASS-user] Re: tin to raster dem: SOLVED
Thomas Adams Thomas.Adams at noaa.gov
Sun Jun 18 06:33:37 EDT 2006
Ivan,
Do you mind posting an example of your results? Also, out of curiosity,
how do you plan on making use of this capability?
Regards,
Tom
ivan marchesini wrote:
> Dear all, dear Maciek,
> many thanks to all for the answers..
> the solution proposed by Maciek works really well...
> it seems that the module v.surf.nnbathy modified changing in line 138
> "-P alg=nn" with "-P alg=l" is able to create a plane passing for tree
> rasterized points!!!!
> many thanks!!!
> Ivan
> Il giorno sab, 17/06/2006 alle 13.00 +0200, Maciek Sieczka ha scritto:
>> On Fri, 16 Jun 2006 10:50:23 +0200
>> ivan marchesini <marchesini at unipg.it> wrote:
>>> Dear all...
>>> I have been able to create a tin starting from the v.delaunay module
>>> and then manual editing the v.delaunay output exported with v.in.ascii
>>> (format=standard)
>>> now I can see, using nviz, the some filled triangles in the 3d
>>> space...!!!!
>>> now the problem:
>>> I would like to transfrom the tin surface in a raster surface...
>>> is it possible in some way!!!!
>>> any idea????
>> This *might* work:
>> Get the apices of your triangles into points vector, rasterize it
>> (v.to.rast) and feed to my r.surf.nnbathy
>> (http://grass.gdf-hannover.de/wiki/GRASS_AddOns).
>> You will only have to modify the script slightly. In line 138 put "-P
>> alg=l" instead of "-P alg=nn". This will make nnbathy triangulate
>> only, without any smoothing.
>> Let me know if it worked.
>> Maciek
>> P.S.
>> Please don't post to grasslist at baylor.edu. Post to
>> grassuser at grass.itc.it.
>> CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
>> ZAPRASZAMY
>> www.skarpatravel.pl
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
