[GRASS-user] FW: How to allow a file browser dialog in shell scripts
Markus Neteler neteler at itc.it
Thu Jun 22 08:55:39 EDT 2006
Hamish wrote on 06/22/2006 11:35 AM:
>Eric wrote:
>>I'm trying to create a script to load plan ascii files as input. I'm
>>unfamiliar with all of the possible variations for the gisprompt
>>parameter structure. I want to allow the user to browse the Mapset to
>>load each ascii file.
>add to the option definition:
>#% gisprompt: old_file,file,input
>e.g. m.proj.
>>While we're on the topic, can anyone explain why there are usually
>>several gisprompt parameters allowed for in most Grass shell scripts?
>>What do all these mean?
>somewhere deep in the programmers' manual or lib/gis/parser.c ...
>from memory:
>old/new  - whether to open map/file browser; checks that it won't overwrite
>element  - the directory in $MAPSET, if applicable
>prompt   - mostly unused nowadays?
Here is the list:
http://mpa.itc.it/markus/grass61progman/
 -> File List <http://mpa.itc.it/markus/grass61progman/files.html>
   -> paerser.c
       http://mpa.itc.it/markus/grass61progman/parser_8c-source.html#l00326
Markus
Markus
