[GRASS-user] Makefile:22: include/Make/Platform.make: No such file or directory
Markus Neteler neteler at itc.it
Fri Jun 23 08:08:15 EDT 2006
On Fri, Jun 23, 2006 at 01:47:50PM +0100, David wrote:
> Thanks to those who replied to my previous thread i.vpoints. I have been trying the CVS install and hit errors in the make process, I get similar errors using both 6.0-CVS and 6.1-CVS snapshots from http://grass.itc.it/faq/cvs_howto.html
> cd /usr/local/src/grass61
> tar xzf grass-6.1.cvs_src_snapshot_2006_06_18.tar.gz
> export CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
> cvs login
> cvs up -dP
> cd grass-6.1.cvs_src_snapshot_2006_06_18
> CFLAGS="-ggdb -march=k8 -Wall" ./configure \
> 	--with-tcltk-includes=/usr/include/tcl8.4 \
> 	--with-motif \
> 	--with-motif-includes=/usr/include/qt3 \
> 	--with-readline \
> 	--with-cxx \
> 	--with-odbc \
> 	--with-sqlite \
>  	--with-freetype \
> 	--with-postgres-includes=/usr/include/postgresql \
> 	--with-freetype-includes=/usr/include/freetype2 \
> 	--with-ffmpeg \
> 	--with-ffmpeg-includes=/usr/include/ffmpeg \
> 	--enable-64bit \
> 	--with-libs=/usr/lib64 \
> 	--with-ffmpeg \
> 	--with-tiff \
> 	--with-blas \
> 	--with-lapack \
> 	2>&1 | tee config_log.txt
> make distclean
here is the problem: don't run 'make distclean' because it will remove
the configuration again.
Just:
> make
then (maybe as root):
 make install
Cheers,
 Markus
> Makefile:23: include/Make/Grass.make: No such file or directory
> make: *** No rule to make target `include/Make/Grass.make'.  Stop.
> if I use the locate command...
> updatedb
> locate Grass.make
> /usr/local/src/grass60/grass-6.0.cvs_src_snapshot_2006_06_17/include/Make/Grass.make.in
> /usr/local/src/grass61/grass-6.1.cvs_src_snapshot_2006_06_18/include/Make/Grass.make.in
> so while a Grass.make.in exists the required Grass.make appears to be missing and the same applies regarding Platform.make
> I'm not sure how to proceed with configuration from here.
> Many thanks in advance for any hints
> Dave
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
