[GRASS-user] Newbie adding additional modules?
Nagesh Bhatkar bnagesh at nio.org
Tue Jun 27 01:06:55 EDT 2006
Copy the r.out.netcdf module into the ~/grass-6.0.0/raster/ source directory
Create a Makefile in the r.out.netcdf directory if there doesnt exist
one, and then run
"make" . If the Makefile already exist, make sure -lnetcdf is added to
the LIBES
The following is the Makefile:
MODULE_TOPDIR = ../..
PGM = r.out.netcdf
LIBES = $(D_LIB) $(DISPLAYLIB) $(RASTERLIB) $(GISLIB) -lnetcdf
DEPENDENCIES= $(D_DEP) $(DISPLAYDEP) $(RASTERDEP) $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
default: cmd
Hamish wrote:
>Barry Baker wrote:
>>It has been nearly 16 years since I used Grass and now coming back.
>>I have GRASS up and running on my Mac PowerBook G4 with OS X 10.4.6
>>Now I am trying to install the r.out.netcdf module and am at a loss as
>>to how to go about it.  Any help would be appreciated.
>Unless r.out.netcdf is packaged for the new GRASS 6.1 Extension Manager
>(GEM), and I'm pretty sure it isn't, you will need the full grass source
>code to compile it.
>after ./configure, make of source code,
>mkdir raster/r.out.netcdf/
>cd raster/r.out.netcdf/
>cp r.out.netcdf_source_files/* .
>make
>alternatively and probably simpler, use r.out.gdal for NetCDF output:
>GRASS> gdalinfo --formats
>  GMT (rw): GMT NetCDF Grid Format
>  netCDF (ro): network Common Data Format
>In my old version of GDAL, the GMT version is only one which it can
>write to. I'm not sure what the latest version can do.
>http://www.gdal.org/formats_list.html
>another indirect way is to use r.out.mat to make a Matlab array and
>to save a NetCDF file from there. (r.out.mat is untested on big-endian
>AFAIK, if that doesn't work use raw r.out.bin -> Matlab)
>If you are looking to send output to GMT, there are other options &
>scripts that can be used. see r.out.gmt on the wiki add-ons page and:
> http://169.237.35.250/~dylan/grass_user_group/#GMT_and_GRASS-overview
>Hamish
>_______________________________________________
>grassuser mailing list
>grassuser at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grassuser
