[GRASSLIST:10722] Re: How to save to PERMANENT
Michael Rensing michael.rensing at shaw.ca
Fri Mar 3 12:14:06 EST 2006
OK, that makes sense, but when I start in the PERMANENT mapset, I don't
see any of the maps in my other mapset. Does that mean there's some kind
of permission problem, or do I need to remember the names of the other
maps, or ...
Thanks again,
Michael
Huidae Cho wrote:
> Try "g.copy from=map at mapset to=map" in the PERMANENT mapset.  The to= option of
> g.copy does not support @MAPSET, so you must run grass with the PERMANENT
> mapset.
> Huidae Cho
> On Wed, Mar 01, 2006 at 10:15:56PM -0800, Michael Rensing wrote:
>> Hello; a real noob question: once I have a map layer I want to keep/share, how
>> do I copy it into the PERMANENT location? When I tried r.copy, I got an error
>> that a file does not exist.
>> TIA
>> Michael
