[GRASSLIST:10744] Re: r3.out.v5d
Andrea andrea.iescheck at ufpr.br
Sun Mar 5 16:18:43 EST 2006
Maciek,
I did what you suggested:
Run r3.out.v5d from Grass CLI and import r3.out.v5d output back into Grass.
The file is imported to grass but when I try to visualize it with nviz (the
same way I do with the original file) the nviz panel quits abruptly!
So I think the problem is with the exported file (r3.out.v5d command).
I don´t know any other program able to open vis5d files but I´ll try the
paraview with r3.out.vtk as Markus Neteler suggested.
Thanks
Andrea
----- Original Message -----
To: <andrea.iescheck at ufpr.br>
Cc: <GRASSLIST at baylor.edu>
Sent: Sunday, February 26, 2006 6:47 AM
Subject: [GRASSLIST:10582] Re: r3.out.v5d
> On Sat, 25 Feb 2006 16:14:36 -0300 (BRST)
> andrea.iescheck at ufpr.br wrote:
>> Maciek,
>> When I select the icon r3.out.v5d it opens the command box where I
>> select the input grid3d file, type the output file name and run ...
>> There is a ligth showing the status of the command but it doesn´t
>> completely ends and there is no error messages. Anyway the output
>> file is created, but when I try to import it using vis5d the program
>> (vis5d) prompts an error: Making ap ...
>> Writing a 4.3 file!
>> S: lowlev=0 nl=30
>> Error in v5dCreateFile: open failed
>> Actually I´m not sure if there is a problem with the exported file or
>> with vis5d program!!
> Right. So I won't know either, I don't use vis5d. The only things I can
> adivise to you is to:
> 1. Run your r3.out.v5d from Grass CLI, to make perfectly sure there are
> no errors when executing the command - Grass>=5.7 GUI hides error
> messages like segfaults from the user. It was reported:
> https://intevation.de/rt/webrt?serial_num=3010
> 2. For a cross test, import your r3.out.v5d output back into Grass with
> r3.in.v5d. In case it doesn't fail you could consider blaming vis5d
> eventuality.
> Do you know any other program able to open vis5d files so you could
> verify more?
> Maciek
> W polskim Internecie są setki milionów stron. My przekazujemy Tobie tylko
> najlepsze z nich!
> http://katalog.panoramainternetu.pl/
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.375 / Virus Database: 268.1.1/271 - Release Date: 28/2/2006
No virus found in this outgoing message.
Version: 7.1.375 / Virus Database: 268.1.2/274 - Release Date: 3/3/2006
