[GRASSLIST:10821] v.in.ascii error
Pierluig De Rosa sisma66 at tiscali.it
Wed Mar 8 08:47:52 EST 2006
Dear GRASS users,
I need to import an ascii file into a point vector file, and I'm using
v.in.ascii command.
 My ascii file have three columns (x coordinates, y coordinates, ppm value)
with fields separator "|" (pipe).
the string command I used is:
v.in.ascii input=/home/pierluigi/Desktop/zinc output=zinc format=point fs=|
'columns='\''x double precision, y double precision, ppm double
precision'\''' x=1 y=2 z=0 cat=0
but I have this error
DBMI-DBF driver error:
SQL parser error in statement:
create table zinc ( cat integer, 'x double precision, y double precision, ppm
double precision' )
Error in db_execute_immediate()
GRASS_INFO_ERROR(5553,1): Cannot create table: create table zinc ( cat
integer, 'x double precision, y double precision, ppm double precision' )
Can anyone tell me why I find this driver DBF error??
Thanks
Pierluigi
Pierluigi De Rosa
Department of Enviromental & Civil engineering
Faculty of Engineering
Perugia (Italy)
