[GRASSLIST:10833] Re: v.in.ascii error
Stuart Edwards sedwards2 at cinci.rr.com
Wed Mar 8 18:37:22 EST 2006
About a month ago I started a thread 'v.in.ascii quirk' (Grasslist
10237) and after some backwards and forwards with Maciek Sieczka, he
determined that there was a bug (at least one IMO) and forwarded it
to the developers list.  I've never heard of a resolution. It does
seem that this is a fundamental issue for data input and while I can
now work with the command, it is probably one of the most syntax
sensitive commands for the *nix impaired user to execute.
Stuart Edwards
On Mar 8, 2006, at 5:32 PM, Hamish wrote:
>> I think your command should look something like this:
>> v.in.ascii input=/home/pierluigi/Desktop/zinc output=zinc
>> format=point
>> fs=| columns='x double, y double, ppm double' x=1 y=2
>> From the command line yes, but quote the pipe (|).
> so if you try:
> G6> v.in.ascii input=/home/pierluigi/Desktop/zinc output=zinc \
>   format=point fs='|' columns='x double, y double, ppm double' x=1 y=2
> It should be ok. The shell needs to be protected from special chars
> (pipe is the redirect command) and also needs to be told that
> multiword
> answers belong with a single option. The GUI and SQL don't need to be
> protected as such.
> If you are running from the GUI, you should not quote the pipe (|) or
> the column names/types:
>> SQL parser error in statement:
>> create table zinc ( cat integer, 'x double precision, y double
>>  precision, ppm double precision' )
> The ' before the x and after precision should not be there. You are
> quoting too much.
>> I realised that the gui of v.in.ascii usually puts together the
>> command incorrectly, so I always use the cli to import ascii files.
> How so? If it is broken we can fix it, but I don't think it is broken.
> Hamish
