[GRASSLIST:10863] Re: Bus Error in g.remove
Michael Barton michael.barton at asu.edu
Fri Mar 10 01:51:26 EST 2006
This turned out to be a problem in compiling the Mac OSX binary. It has
something to do with GDAL.
Michael
On 3/9/06 8:14 AM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> Except that I reported this bug last August, and it happens with
> 6.0.1 and 6.1CVS.  I haven't tried 6.0.2 yet.
> On Mar 9, 2006, at 1:33 AM, Hamish wrote:
>> Just a thought,
>> in the past weeks some code was changed to replace system calls with
>> their C equivalents. Maybe this has something to do with it. I can't
>> connect to the CVS-web interface currently to check.
>> Look for recent changes in:
>>   http://freegis.org/cgi-bin/viewcvs.cgi/grass6/general/manage/
>> Hamish
>> On Wed, 08 Mar 2006 21:04:54 -0600
>> Dave Kent <dkent at sasktel.net> wrote:
>>> Thanks for the insight.  I went back to the Nov 05 binaries and
>>> Janurary CVS version and things work.  That will be fine for now.  I
>>> guess learning how to build wouldn't  be a bad thing.
>>> Thanks for your help.
>>> Dave
>>> On Mar 8, 2006, at 6:40 PM, William Kyngesburye wrote:
>>>> This is probably the same bug Michael Barton reported yesterday
>>>> (#4152) and I reported last August (#3585).  Specifically, when
>>>> GRASS is built on OS 10.3 Panther (GCC 3.3), and GDAL has Postgres
>>>> support.  It's probably happening for you in Tiger because Lorenzo
>>>> builds with Panther compatibility - either on Panther, or on Tiger
>>>> using the Panther SDK.  A Tiger-only build (GCC 4) is unaffected.
>>>> It's a strange bug - I can build GRASS with GDAL without Postgres
>>>> support, then update GDAL to include Postgres support and it still
>>>> works.  It's only when GDAL has Postgres support *at the time GRASS
>>>> is built*.  I've tried various combinations of static and dynamic
>>>> Postgres libraries (and the exact same ones used for Postgres
>>>> support in GRASS) and other options in GDAL and GRASS and GRASS
>>>> with/without its own Postgres support.
>>>> On Mar 8, 2006, at 6:14 PM, Dave Kent wrote:
>>>>> I am using Grass 6.1CVS on Macintosh with the most recent
>>>>> Macintosh binaries.
>>>>> g.remove gives the following error.
>>>>> child killed: bus error
>>>>>     while executing
>>>>> "exec -- $cmd --tcltk"
>>>>>     (procedure "execute" line 4)
>>>>>     invoked from within
>>>>> "execute g.remove "
>>>>>     (menu invoke)
>>>>> This started quite suddenly, possibly consistent with messing with
>>>>> AWK post I had yesterday.
>>>>> I get the same error with g.copy, g.rename but not g.list
>>>>> I have reinstalled the binaries and the application.
>>>>> There was a not too similar message in the archives which relates
>>>>> to the environmental variable file being corrupted.  I cannot find
>>>>> this file and haven't tried removing it.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
___________________________
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287
WWW - http://www.public.asu.edu/~cmbarton
Phone: 480-965-6262
Fax: 480-965-7671
